HELP ON 2.2L 1994 S-10 2wd pick-up
Old May 26, 2010 | 01:06 PM
4x4blazerguy's Avatar
Smile HELP ON 2.2L 1994 S-10 2wd pick-up
I have a question on the 2.2L 4cyl. Do ALL these engines in this year have REVERSE ROTATION COOLING?
Thanks
Old May 26, 2010 | 05:16 PM
I believe they all are reverse rotation in terms of the way they spin as compared with the crankshaft. However, I do not believe that they are reverse flow like the old LT1 engines were where the pump pulled coolant out of the block instead of pushing it into the block.
Old May 26, 2010 | 05:27 PM
Thanks for that info. When a friend went to buy a fan clutch they said it was a reverse unit. He is 75 miles from the truck & didn't want to head to it & find it was the wrong part. From looking on Rockauto at water pumps they showed both, it appeared that may have either. So we will find out. He headed home to finish up his job more confident he has the right part.
Thanks.
Old May 26, 2010 | 05:33 PM
Have him look at the belt routing. If the belt wraps around the pulley with the smooth side to the pulley, it is reverse rotation. If it wraps around with the grooved side down, it is same rotation. Again, this is in relation to the crankshaft rotation.
*EDIT* - All of the belt routing diagrams I could find for that year showed reverse rotation.
miablazer
Apr 1, 2010 03:12 PM
sporty_drew
Nov 24, 2009 03:31 PM
rogggg1020
Oct 25, 2008 11:10 AM
dbleon
Mar 31, 2008 09:17 PM
Hontzy1291
Headers, Intake, & Exhaust
Jan 15, 2008 04:22 PM
