How many miles does your original Vortec V6 have?
Old May 7, 2013 | 04:55 PM
  #151
chris015's Avatar
NOW at 190k on the jimmy... still running smooth like day one, the only problem is the 1 seecond puff of oil burn at startup from the valve seals. But, I do not lose sleep over it.
welcome to chevy/gmc. they do it lol...So far ive yet to see a puff though from my sonoma. knock on wood.
Old Jun 10, 2013 | 06:39 PM
  #152
racsan's Avatar
racsan is on a distinguished road
Originally Posted by racsan
Well, the '97 is now at 207,000 miles, thought we were retiring it and traded it back to dad for a 96 with 185,000. Well, last sunday i developed a bad knocking (engine sounds like a diesel) so were back in the 97 and i'll tear into the 96 and see what i find. I have a 94 parts blazer i might pull the engine out of, it ran when parked, that chassis has 198,000.
The '96 now has a '96 engine from a S10 truck with over 220,000 miles. Bearings looked good, put a new oil pump in, front/rear crankshaft seals, oil pan gasket, remote oil filter lines, and a new radiator. Seems to run ok, even though the back 2 cylinders were a little low on compression compared to the front 4 (140 vs 170) and i picked from the best used ignition componets i had to choose from. Timing chain didnt seem to have any streach to it so i left it alone. Runs better than i thought it would, certianally better than my diesel-sounding original engine with all those spun bearings. Lol
Old Jun 10, 2013 | 07:29 PM
  #153
er0ck273's Avatar
er0ck273 is on a distinguished road
159,100. hoping to get her to 200k
Old Jun 11, 2013 | 07:58 PM
  #154
ExpressEN1's Avatar
ExpressEN1 is on a distinguished road
It was over 170,000 when the odometer went out.
Old Jun 11, 2013 | 08:07 PM
  #155
slcblazer's Avatar
slcblazer is on a distinguished road
Right at 180000 running fine.
Old Jun 12, 2013 | 01:36 AM
  #156
step66's Avatar
Running strong and delivering excellent fuel economy at 205k. I should have stayed with with 10w-30 instead of going back to 5w-30 as this site recommended:uses a 1/2 qt every 2k which is still OK,compared to my Lincoln that uses a qt every 600 miles and doesn't leak it-Fords just use oil. But I will be going back to 10w-30 at the next change!
97 Jimmy-2nd owner. >65k in 3 years with no let downs or surprises! Its a keeper!
Old Jun 12, 2013 | 03:25 PM
  #157
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
My 94 jimmy 4x4 still going with 226,000. Got 17 mpg last fill up, but has had a burnt exhasut valve for a while. Still drive it when I want but plan to repair eventually. Just causes a slight skip at idle.
The 96 had 260,000 when the intake gasket went unnoticed, could have gone longer but people make mistakes.
Old Jul 24, 2013 | 11:26 AM
  #158
Jimmy Williams's Avatar
Jimmy Williams is on a distinguished road
I have a 92 s10 Blazer 4x4 with 217,000 miles. Now that I fixed the issues that plagued it when I bought it, it runs like a champ.
Old Jul 24, 2013 | 04:02 PM
  #159
Wisco Blazer's Avatar
Wisco Blazer will become famous soon enough
2000 s10 blazer.
117,000 miles on motor.
Transmission was rebuilt about 2000 miles ago.
Now it has Transgo shift kit, and a corvette servo *Very Firm Shifts*
Old Aug 9, 2013 | 02:56 PM
  #160
DrkBluePenguin's Avatar
DrkBluePenguin is on a distinguished road
I cracked the block at around 150k when the water pump went out. Everything stock. $3k later had a new engine put in.
2000 2dr odo 198232
