I need help finding Spider Fuel Injector
Old Feb 8, 2024 | 11:01 AM
Blaz_r's Avatar
Blaz_r is on a distinguished road
Default I need help finding Spider Fuel Injector
I have bought 2 Multi Port Fuel Injectors for my 2004 Chevy Blazer 4.3 Vortec. Both had the same manufacturing defect. They started spraying fuel from the nipple underneath the intake and return ports.
I have searched for either Delphi or AC Delco MPFI now everywhere. I can't find one on the either of their websites. I have found 2002 spider injectors but it says does not fit my vehicle.
I thought about finding one in a salvage yard and switching out the individual injectors.
The oem fuel metering body is a solid cast whereas these cheap Chinese garbage parts run that nipple through a hole that ends up leaking.
I have read some good things about Standard parts and Amazon does sell one for my blazer but again it is made in China.
Its not difficult to dismantle these units and switch parts. So I am willing to do anything that will work. I have had to remove the plenum 4 or 5 times in 2 months. Im pretty good at it now but I never want to do it again.
https://youtu.be/0dyFSyOesDk?si=RNX0AICwhCXk95OS
Old Feb 8, 2024 | 03:57 PM
Have you tried cross-referencing parts numbers for the injectors for the various years to confirm what would fit?
Old Feb 8, 2024 | 04:09 PM
Here's a link with lots of cross-reference info that may help.
I saw a GM injector assembly for a 2002 at Rock Auto. Perhaps it could work for you.
http:/www.motormanfuelinjection.com/page/subpage/New-Fuel-Injectors/GM-V6-MFI.htm
Old Feb 9, 2024 | 01:08 PM
Blaz_r's Avatar
Thank you. I don't know why i am having such a hard time. Find an oem mfi
I checked the link and they are backordered. Such luck. That was exactly what I was looking for. Thanks again. I will probably buy the fuel metering body from enay $25 and switch everything over.
Old Feb 9, 2024 | 02:42 PM
You are welcome.
I was thinking that perhaps you could determine from the information on that website if the OEM one for a 2002 I found at RockAuto might work.
Old Feb 9, 2024 | 03:21 PM
Blaz_r's Avatar
You are welcome.
I did see the GB reman but its a scpi i ​​am seeking a mfi. The ultra brand doest say anything about being oem and the standard is the same way.
I have read online that some diy individuals fix leaks with a plastic welder. At this point my choices are weld or buy an oem fuel meter body from ebay and swap the lines. I have 4 days to make a return or im stuck with it.
Old Feb 21, 2024 | 04:31 AM
adamiscool's Avatar
adamiscool is on a distinguished road
Motor Man | GM Vortec 4.3L Fuel Injector Spider Assembly 25379923 - Returnless | eBay
This is from the Motorman company, only place I'm aware of to get the real GM MPFI spider.
Graveyard
May 24, 2016 11:33 AM
kaynos
Aug 1, 2011 11:42 AM
GregM
Apr 1, 2011 06:30 AM
reapher
Performance & Brainstorming
Jan 18, 2011 12:06 PM
98Ltblazer
Dec 14, 2010 03:34 PM
