Indicator lights 4x4 switch. 1999 blazer.
Old Nov 28, 2018 | 02:00 AM
Thebard's Avatar
Thebard is on a distinguished road
Question Indicator lights 4x4 switch. 1999 blazer.
Hi, I have a 1999 Blazer S10. 4x4. The four-wheel system works, but the indicator lights on the buttons only work occasionally. What could be the reason for that?
Best regards
Bard
Old Nov 28, 2018 | 07:36 AM
I'm thinking bad solder points on the inside. My 4HI is doing the same thing. I can hear the 4x4 engaging, but the light is iffy... gotta tap it sometimes for it to come on...
Old Nov 28, 2018 | 11:43 AM
Thebard's Avatar
Thanks DoneL. Probably that's the problem. Maybe change the indicator switch. Not too expensive :-)
Old Nov 28, 2018 | 06:20 PM
go chevy's Avatar
A new 4x4 switch on your dash costs between $35 too $45 bucks, depending on where you live. That is for a 3 button system, if you might have the 4th button, I bet it will be higher...
Old Nov 29, 2018 | 01:41 AM
Thebard's Avatar
Hi, I am in Norway, so I order normally from Rockauto. Here in Norway all things are to expensive.
Old Oct 17, 2020 | 09:41 AM
Dahut's Avatar
Dahut is on a distinguished road
Best regards
Bard
I replaced my dash switch from Oriliely for 20 bucks, if your system is all working I would try replacing that.
Stevenn
Sep 27, 2014 04:57 PM
Jimmybeatergal
Nov 26, 2013 02:27 PM
clbychil
May 8, 2013 07:32 PM
mommaoften
Mar 20, 2013 09:30 AM
jabbadahutt
Dec 31, 2010 08:23 PM
