lost photos
Old Mar 23, 2021 | 10:29 AM
dgriffinhere's Avatar
dgriffinhere is on a distinguished road
Default lost photos
i am replacing the engine in my 98 blazer.....took many photos of electrical hookups and the other day let a large handle fall and it crushed my phone. will a chilton or haynes manual show enough info to help make sure things are reconnected correctly? i think most sensors have different shaped hookups so maybe it wont be too bad....just wondering where would be a good place to look.......thank you for any and all info......dg
Old Mar 23, 2021 | 01:59 PM
If you lay the harness over the engine in its normal position, things kind of fall into place. Most connectors will only fit where they're supposed to go, and the wires will generally only reach the right connectors. It may look intimidating, but it's really not that bad when you start doing it.
Old Mar 23, 2021 | 05:39 PM
thank you, tom fot that answer. last year i was going to do a small task on a taurus and ended up pulling the heads and didnt take any photos and everything went back into place as you said. crossing fingers that the same will happen with my blazer!!! thank you again for your help and input!!!! david g.
Old Mar 23, 2021 | 07:34 PM
You're welcome, and good luck. If you get stuck on anything, post a picture and I'm sure somebody will be able to tell you how it goes.
Remington Laisy
Apr 3, 2019 02:09 PM
Chrisdot
Sep 17, 2018 07:48 PM
johnnylovsey
Feb 8, 2016 08:01 PM
CanadaBlazer
Nov 19, 2008 02:36 PM
ChrisAttebery
Jul 10, 2007 05:46 AM
