No Fluid
Old 08-09-2010 | 10:15 AM
01BlackBeauty's Avatar
01BlackBeauty is on a distinguished road
If the plunger is in the depressed position then the proportioning valve should center itself once fluid pressure is applied to it. Did you prime (bleed) the master cylinder prior to trying to bleed the brake lines?
Old 08-09-2010 | 11:53 AM
sgp7679's Avatar
sgp7679 is on a distinguished road
the master cylinder was never run dry with fluid, so no i didnt bleed the mc. Im thinking I may have to much air in my line and Im going to try gravity bleeding the rear.
*EDIT 1*
well been gravity bleeding right rear for an hour now and nothing is coming out
*EDIT 2*
ok finally got it, whoever owned it last plugged the line coming from the master cylinder to the rear brakes with a screw because of the busted cylinder. glad it was just a screw. Brakes are working good now.
Old 08-10-2010 | 02:20 AM
old skool luvr's Avatar
WTF is wrong with some people?!!!
Old 08-13-2010 | 02:52 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
what did this screw plug look like?
Old 08-13-2010 | 10:25 AM
sgp7679's Avatar
just a regular old screw
Old 08-13-2010 | 12:00 PM
I dont understand how a regulaer screw would seal it? there is an inverted flare inside there and the screw would have to have to proper seat to seal properly.... and where was this screw put exactly? im only asking because i may have to do it to my truck temporaly so i can drive it to the shop to get a flare done on the rear line by the shop. please help me and let me know
thanks
Old 08-13-2010 | 05:38 PM
sgp7679's Avatar
take the first line that goes to the rear brakes on the master cylinder of and get a round head screw that fits perfectly into the line and stick the screw in the line and hook it back up to the master cylinder and it stops the fluid.
BrinkDiamond
03-02-2014 04:50 PM
Mjseyler
01-05-2010 01:44 PM
DaleA
01-13-2009 09:50 PM
fruccoman
02-15-2006 08:08 PM
Derbytown
08-23-2005 01:00 PM
