Normal?
Old Sep 1, 2015 | 04:07 PM
No false Bravada's Avatar
No false Bravada is on a distinguished road
Default Normal?
The Bravada isn't giving me any problems, I just wanted to see what you all think. After a 25 minute drive of which about 18 or so was highway driving (70-75 mph), my temp was about 180-190 (going off the gauge), my oil pressure was about 37 psi, volts were at 13.5-14, and it was idling at about 600 rpm.
Isn't running rough, accelerated fine, stops fine. What do you all think?
99 Bravada, 219k miles.
Old Sep 1, 2015 | 04:46 PM
richphotos's Avatar
Sounds normal to me
Old Sep 7, 2015 | 10:07 PM
silverside's Avatar
silverside is on a distinguished road
If nothing bothers on her smooth ride, should be normal.
Old Sep 7, 2015 | 11:20 PM
newguy's Avatar
yep, all is fine
Old Sep 8, 2015 | 12:12 AM
LeWhite's Avatar
Seems quite acceptable though I personally would like to see coolant ten degrees hotter for a possible increase of fuel economy. 180 for more than a couple of minutes will set a diagnostic trouble code.
Old Sep 8, 2015 | 08:41 AM
Maybe it's about time for a new tstat and probably an ECT sensor.
Old Sep 10, 2015 | 02:05 PM
Tajohns34's Avatar
Sounds good to me.
Old Sep 27, 2015 | 10:12 PM
Oil change time. I drained off a little oil and replaced it with Sea Foam, and it runs better, before the oil change. I've been driving it for a few days before actually changing it. There was a slight ticking sound coming from the passenger's side, but now it's gone. The idling warm oil pressure has gone up to about 45+psi, and it accelerates so much harder now.
I love Sea Foam.
amkonyk
18
May 30, 2009 11:32 PM
jimmyboy
Lifting Tech
Oct 29, 2007 02:12 PM
EuroGoldLS
Engine & Internal
Jun 7, 2007 11:45 PM
blazinloud
Dec 31, 2006 02:03 PM
Loud_01_Blazer
Oct 4, 2006 02:20 PM
