not a blazer question...
Old May 18, 2021 | 02:42 PM
bravo99's Avatar
Default not a blazer question...
94 f250 300 i6 starter
so... can tranny fluid soaking the starter ground cable actually cause a bad ground like the solenoid is going out? btw solenoid is way up on passenger fender. truck shorts on ignition. dome lights and all electrical will not immediately come back. all cables recently replaced big 3-style, brand new alternator. battery okay and starts the truck when something shorty is not acting up.
Old May 19, 2021 | 08:36 AM
The transmission fluid probably wouldn't cause that, but it definitely sounds like you're on the right track looking for a bad connection. If somebody else can attempt to start it for you (or you use a remote starter), it should be pretty easy to probe it with a test light to see where the power flow stops. Check the grounds the same way.
Sdurreman
Mar 10, 2018 09:24 PM
jnewtonav
Feb 10, 2016 09:02 PM
chris015
Dec 3, 2011 08:38 AM
Jonas
Jun 28, 2010 01:01 AM
rhs856
Jan 10, 2010 03:04 AM
