nuts, line fitting @ front brake swap
Old Jun 16, 2014 | 10:51 PM
chevyblazer's Avatar
chevyblazer is an unknown quantity at this point
Default nuts, line fitting @ front brake swap
i swapped my 95 single piston brake to 98+ dual piston brake setup; with knuckle, wheel bearing, caliper, bracket, ABS module and a good number of other hardware replaced; everything works fine.
Except for the front brake line, just couldn't connect..., i keep the old 95 model year front brake line tubing there, with the old nuts on both ends, coz they are same as the 98+ new models.
On the right side, the tubing's nut can't fit in the right front brake hose(newly bought 98+ front brake hose); and on the left side, the tube is connected to a 7/16 24 fitting, but this fitting doesn't fit in the new brake pipe from ABS module...
anything wrong with them? anyone would give me a hand???
Old Jun 19, 2014 | 09:26 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
98 is metric brake line
Old Jun 20, 2014 | 12:32 PM
abig84's Avatar
the fittings that go into the abs boxes are always some goofy size that is hard to locate at a local parts store. ive always just cut the line a little bit back off the abs line, put a new standard fitting on it and just reflare that end. if the line goign to the abs is rotted then just re use the old fitting
Xavier
Apr 11, 2014 11:49 AM
wisowebs
Dec 26, 2013 06:58 PM
bigjon720
Apr 1, 2011 07:17 PM
NYC86ZC
Dec 12, 2010 08:21 AM
ChevyFamily
Jul 10, 2009 06:41 PM
