Offroad lighting?
Old Jan 16, 2014 | 03:09 PM
newguy's Avatar
Originally Posted by Diaita
A few guys around here have them, and they are very bright.
A small bar in this style of hood would be pretty sweet too.
Gotta agree
Old Jan 16, 2014 | 09:02 PM
swells87's Avatar
swells87 is on a distinguished road
Originally Posted by Sandman
Seems like a pretty viable option! How much did it run you to get it all set up and running?
The lights were 11$ each and about 40 for the HID setup. So all said and done around 65$ or so, plus whatever wiring and relays you may need.
Old Jan 17, 2014 | 08:25 PM
gitch93's Avatar
gitch93 is on a distinguished road
matter of opinion I run 4x roof ligts that are 100 watt bulbs and they are not as bright as I want them to be. I also have 2x cree led offroad lights that are 18 watts each and are as bright if not brighter then my headlights with h,i.ds. I also have 2x cree led fog lights and 2x 4 inch round lights on my stinger bar with 100 watt bulbs. I am removing the roof lights to replace it with a cree led light bar. they are brighter and they have a flood/spot light combo mixed in. its a slim design and u can modify it as quick release. they also draw less currant for when ur offroading at night whoch is less strain on ur battery and alternator. check ebay or amazon for some deals on them
Old Jan 17, 2014 | 11:26 PM
Diaita's Avatar
I see Rigid has curved light bars in the new catalog for us non jeep guys now.
Old Jan 20, 2014 | 01:25 AM
Sandman's Avatar
Sandman is on a distinguished road
I think I'm going to settle with this bad boy...
Tuff Stuff Performance 40" Led Off Road Led Light Bar Flood/Spot Combo Beam- 3W Led-240W-15, 000 Lumen : Amazon.com : Automotive Tuff Stuff Performance 40" Led Off Road Led Light Bar Flood/Spot Combo Beam- 3W Led-240W-15, 000 Lumen : Amazon.com : Automotive
Unless my measurements are way off, it should fit nicely...tucked out of the way, and a low profile look.
Gotta wait for my next paycheck, so I'm still in the planning stages. I'm wondering if anybody can give me a rundown on how to wire this thing up, (the comments on the item say the instructions are sketchy at best)
I'm thinking of also adding some very small led bars to the back later on as some awesome back up lights >
Thanks for all the feedback!
Old Jan 20, 2014 | 11:22 AM
Diaita's Avatar
Get 'r done! Don't forget pics for us!
Old Jan 20, 2014 | 11:30 AM
Thogert's Avatar
Wiring will really depend on what they mean by 'PROFESSIONAL HARNESS CONNECTOR.' If it's a relay harness, then it should be pretty simple. If you have to add one on your own, it gets a little more complicated. And I wouldn't run that without a relay. You can get switches that are 'rated' for 30 amps, but I wouldn't trust one from any of these auto stores to carry the 20 -25A that thing will pull.
Old Jan 20, 2014 | 01:19 PM
Diaita's Avatar
Relays and fuses are certainly needed with the wattage the bigger bars need. It's a lot easier to run a little 16ga switch wire through to the harness into the interior. And you can pull power to switch a relay from almost anywhere so you could make it so aux lights will only come on when the park lights are on as an example.
wlorton
May 4, 2017 08:15 AM
hardkalik
Feb 26, 2007 10:19 AM
a_tack
Nov 14, 2006 12:49 AM
eslhockey92g
Oct 13, 2006 10:11 AM
idr
Mar 13, 2006 12:33 PM
