Part 15046433 Defrost vent grille
Old Apr 7, 2014 | 08:12 PM
HunterJayMike's Avatar
HunterJayMike is on a distinguished road
Default Part 15046433 Defrost vent grille
I have a 1999 Chevrolet Blazer LS and cannot find this part that has been discontinued.Anyone have a site I can go to that has the sensor hole?
Old Apr 7, 2014 | 09:06 PM
chris015's Avatar
im guessing its the round style? (on the ends)
Hard to find,and cant find em used as 99.999% of the time they crack when you pull em!!!
If its the square style? easy. junkyards got em. they dont crack like the rounds.
ive got a few (but without the sensor holes i think)
Old Apr 8, 2014 | 09:44 AM
Default Defroster
Mine did break apart when dash was pulled
Old Apr 8, 2014 | 08:10 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
have you checked ebay? when i was looking for mine a few months ago, i saw a few with sensor holes...but not many
Old Apr 12, 2014 | 07:39 PM
okiedoak20's Avatar
The one with a sensor hile is not available any more
I have the same problem.....I bought one from GM
And made the hole myself....quite simple actually..
I think I have posted pics about it...
Old Feb 27, 2018 | 10:16 AM
billnc's Avatar
billnc is on a distinguished road
Default Sensor hole
okiedoak20 drilled a hole in the grille to allow use of the DRL sensor. I found an after-market one on Amazon without and not sure if they'll be room for the hole diameter that will be needed. Anyone else tried this? Problems? Hole size?
Old Mar 7, 2018 | 10:44 AM
mr.vls's Avatar
Replaced my busted up dash vent in my 2000 Jimmy with a Doorman replacement. However, the doorman does not have a provision for the sensor that is mounted in the center of the dash vent. I removed the sensor from the original dash vent. I broke of the sensor lock tabs and drilled out the center of the Doorman slightly undersize and press fit the sensor into the Doorman dash vent. The sensor looks like a factory installation. I am very pleased with the end result. See my link below on S10 Forum I added a few PICS of my install. The doorman part fit perfect and you cannot tell that the sensor in not factory mounted.
http://www.s10forum.com/forum/f136/r...h-vent-826714/
spider21
Nov 17, 2011 06:27 PM
2drmike
Jun 10, 2010 07:40 PM
BrooklynBlazer
Apr 25, 2007 06:25 PM
kammino
Nov 27, 2006 11:35 PM
moggy59
Jul 26, 2006 08:50 PM
