Priming your oil filter when you change your oil
Old May 17, 2012 | 09:32 PM
Rottidog's Avatar
Originally Posted by TripleBlackBlazer
How do you prefill a filter that mounts sideways?
Yup, my remote oil filter is mounted sideways so it only gets a little oil in it before I can screw it on. I always lube the seal, it makes removal that much easier & seals better.
As for the comment about not filling the filter beforehand because it's unfiltered oil - it's new oil! How dirty could it be?
Old May 18, 2012 | 10:31 AM
91chevywt's Avatar
91chevywt is an unknown quantity at this point
On an S10 where the filter is sort-of small, I don't think it's that important, really doesn't hurt anything either way. If you've ever worked on something larger with a filter that holds 2 quarts I would fill it.
Old May 18, 2012 | 10:40 AM
AuSSenseiter's Avatar
AuSSenseiter is on a distinguished road
Some vehicles I prefill the filter others I dont. Always lube the seal. One thing I do that most dont is adding most of the oil then firing up the engine for 8 seconds. After that I check and top off the oil.
Old May 18, 2012 | 07:13 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
As for the comment about not filling the filter beforehand because it's unfiltered oil - it's new oil! How dirty could it be?[/quote]
Not sure guess you'll have to ask CAT
Old May 19, 2012 | 08:58 AM
fre1809's Avatar
fre1809 is on a distinguished road
Same here lube the filter seal,on my second blazer since 1989. like a ROCK!.
2001 ZR2 Dark cheery metalic
Old Jun 8, 2012 | 12:37 PM
maddie's dad's Avatar
maddie's dad is on a distinguished road
on a filter that can be pre filled, I always do it. True, the oil pump is in the bottom of the oilpan, but, the valve train is way above the oil filter. So, the filter must fill up before the overhead gets any oil. In a small capacity filter it might not matter that much, but in a huge diesel engine with dual oil filters with a capacity of 6 quarts, a couple of seconds without oil pressure is never a good thing. I work for a truck shop where pre-charging the oil filter is procedure everytime an oil change is done.
gtmccormick
Nov 25, 2014 11:35 PM
1sttimejimmyowner
Aug 14, 2013 08:34 AM
blrob5
Apr 27, 2010 03:13 PM
Brian_D
Apr 17, 2010 07:04 PM
tiso_us
14
Jan 21, 2009 02:03 PM
