Question ?
Old May 16, 2008 | 11:06 AM
noom14921992's Avatar
noom14921992 is an unknown quantity at this point
Default Question ?
well i have a 4wd problem. but i would just like to know if i can get a diagram of them or something like that. myy problem is there is a vaccum line that comes from behind the engine-and then goes to a 3 way conector. then one of those hoses goes to a nother 3 way conector. so on the second connector one hose goes to the fire wall and the other goes into the body. but my last one is not connected. where would it go. if i fix this my 4wd should work and be varry happy. thanks for your help
Old May 17, 2008 | 10:55 PM
Default RE: Question ?
no takers?
Old May 18, 2008 | 09:13 AM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
4wd vacuum actuator ?
Zed
Old May 18, 2008 | 11:40 AM
no it does not go to that. i know that much it is on driver side of engine bay
Old May 22, 2008 | 09:51 PM
i dont know please help
Old May 22, 2008 | 11:31 PM
mdehoogh's Avatar
https://blazerforum.com/m_111431/tm.htm
#2 and #9
Old May 29, 2008 | 03:10 PM
vadatara2's Avatar
vadatara2 is an unknown quantity at this point
On my Blazer one hose goes down behind the master cylinder and into a plastic resovoir between the inside sheet metal and the outer fender. All there is is a small plastic tip sticking out where the line goes. Might be your problem.
Old May 29, 2008 | 06:27 PM
where is that. you sound like you are on to something vadatara2
2001Blue
Lifting Tech
Jan 1, 2011 07:15 PM
98Ltblazer
Apr 11, 2010 11:34 PM
Numba1Sean
May 6, 2009 11:48 PM
redfan13
Mar 11, 2008 09:37 PM
Chadoo951
May 6, 2007 07:01 PM
