Rear clunking upon acceleration
Old Aug 10, 2024 | 06:45 PM
Zeroaspect's Avatar
Zeroaspect is on a distinguished road
Default Rear clunking upon acceleration
I have a 2002 4 door chevy blazer that is making a clunking noise from the rear when accelerating starting anywhere from 0-10 mph. Could it be the driveshaft, and is there any repairs that don't require totally replacing the driveshaft?
Old Aug 10, 2024 | 08:03 PM
Could be a u-joint.
Old Aug 12, 2024 | 05:12 AM
BlazerDog97S10's Avatar
As christine_208 posted; check your u-joints. I had the same issue with my 97 a while back.
Old Aug 12, 2024 | 06:04 PM
AJBert's Avatar
Block the tires, put the tranny in neutral, spin the drive shaft. If it moves any at the rear diff, the rear u-joint needs replaced. If it doesn't move, jack up the rear end (front tires blocked), tranny in park, spin the drive shaft. If there is any movement at the front, then front u-joint needs replaced.
venom01
May 24, 2010 09:41 AM
jester429
Sep 3, 2009 08:39 AM
hilsenteger
Apr 14, 2009 06:23 PM
brian2337
Mar 11, 2008 09:46 PM
01ice
Dec 16, 2007 09:07 PM
