Removing Spare Tire?
I have a full-size spare in the back of the blazer, it looks to be attached to some sort of bar but won't swing out or move.
From what I can see the tire should be mounted underneath the car, not in the inside, right?
Anyway, how do I get this thing out? I want to get access behind it, I think I see a jack and some tools back there.
Do you have a 2 door Blazer? The 2 door Blazers either had the spare tire mounted inside or on a carrier that latches to the rear door. It sounds like yours is inside? If that's the case, there should be a wing-nut type screw holding it into place. You have to remove the tire cover and then you can access the screw to free the spare tire.
Just get one at a junkyard! I got mine for $19 off a two door. There is a great thread here: https://blazerforum.com/forum/articl...-thread-48921/
Thanks for the link, that might be a good option for me down the line. I have a big list of stuff to do on the blazer since I have only had it a few weeks now. Going through the suspension, adding a transmission cooler, fixing the electronics in the doors, etc.
I feel ya. I had to get mine running, first, but it was the first thing I did as soon as it was
