Reviving My '91 S-15 Jimmy
Is the Cruise Control mounted on the fender with a vacuum hose and electrical connector? You can test the vacuum side with a vacuum pump and apply vacuum directly to the Cruise control unit. It should hold vacuum without leaking. The vacuum hose from the cruise control goes a brake pedal switch that holds vacuum until you press the brake pedal. Apply vacuum to the hose from the cruise control side and it should hold vacuum until the brake pedal is pressed. The failure is most likely a bad vacuum hose or a leaking diaphragm inside the cruise control unit. Or the adjustment of the brake pedal switch.
