Reviving My '91 S-15 Jimmy
Old Jan 12, 2023 | 09:06 AM
  #21
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
Originally Posted by mr.vls
Is the Cruise Control mounted on the fender with a vacuum hose and electrical connector? You can test the vacuum side with a vacuum pump and apply vacuum directly to the Cruise control unit. It should hold vacuum without leaking. The vacuum hose from the cruise control goes a brake pedal switch that holds vacuum until you press the brake pedal. Apply vacuum to the hose from the cruise control side and it should hold vacuum until the brake pedal is pressed. The failure is most likely a bad vacuum hose or a leaking diaphragm inside the cruise control unit. Or the adjustment of the brake pedal switch.
OK, thanks. I have a MightyVac coming today or tomorrow and I can start hunting for vacuum leaks. What does the vacuum pump on the CC do? I would expect all vacuum to come off of the manifold.
Old Jan 12, 2023 | 04:54 PM
  #22
mr.vls's Avatar
There are 3 vacuum ports on the CC. One is the source from the engine and one is for the brake release switch. The brake switch hose should hold vaccuum. You can make sue you have vacuum to the switch.
Walleye Hunter
Jul 30, 2021 06:44 AM
Jimmy90
Mar 19, 2021 07:40 PM
Dale mccullen
Sep 17, 2017 09:29 PM
Cobble
Aug 17, 2015 04:33 PM
sunadaime
Mar 17, 2009 05:29 AM
