S10 blazer no power atall
Old Feb 26, 2012 | 10:07 AM
LucasMI's Avatar
LucasMI is on a distinguished road
Default S10 blazer no power atall
Went to move it thismorning, turned the key heard a loud click then nothing atall. NOTHING. 2 mins before this I disabled the auto headlights, 1000)ohm 1/2wat resistor. and it worked fine. Any sugestions? un hooked the battery for a second and hooked it back up, still nothing
Old Feb 26, 2012 | 10:37 AM
pettyfog's Avatar
Turn headlights on. Got any? Tug and twist on battery cables while watching them
Old Feb 26, 2012 | 11:51 AM
LucasMI's Avatar
Headlights came on, started the blazer, shut it off, tried starting it again, click, dead. did it again, got the lights to come on but no start
Old Feb 26, 2012 | 12:05 PM
pettyfog's Avatar
Do I have to got through a step by step of what and why? You have a bad connection somewhere. NEeed ALL the symptoms if what and when.
Do the lights dim or go out on the 'click' or not?
Did you turn the headlights on then fiddle the cables or not? How the hell are we supposed to help you fix it ... guess?
Old Feb 26, 2012 | 12:15 PM
LucasMI's Avatar
That problems solved, was bad connection. now I'm having tranny problems. As soon as it goes into gear the engine stalls if I dont get on the gas. If I let off the gass in gear it stalls, If sit in neutral or park and rev the engine it coughs first, let off and the rpm drops to nearly 200rpm coughs and goes back to normal rpm. last time I filled up (thursday night) I dumped a bottle of Injector cleaner in the tank. Had these symptoms before, spark plug wires maybe? probably original.
Old Feb 26, 2012 | 12:30 PM
rriddle3's Avatar
...now I'm having tranny problems...
Doesn't sound to me like any problem with the transmission.
Old Feb 26, 2012 | 12:58 PM
LucasMI's Avatar
Sorry I've just been in a really bad mood since yesterday, anything that can go wrong has gone wrong
zrider79
Oct 15, 2010 09:55 AM
flipzat
Dec 2, 2009 04:05 PM
1991whiteoutblazer
Jan 8, 2009 08:17 PM
nate2003456
Jan 18, 2007 01:10 AM
freeman
Aug 23, 2005 10:55 PM
