Thermostat Housing Gasket
Old Jun 11, 2009 | 01:17 PM
carterx's Avatar
carterx is on a distinguished road
Default Thermostat Housing Gasket
So when I had my rad replaced in Alberta he also replaced the thermostat and all was good. I got to Ontario to find that I was leaking. Got it to a shop and they said that the leak was due to there being no gasket around the Thermostat Housing. Once replaced we drove all the way to NS.
I just called the shop in Alberta now that installed the rad and talked to the tech. He says that this model truck does not require a gasket for the Thermostat Housing. He said that the Thermostat it self inside the housing has a gasket.
So I guess my question is ...... with a 95 4dr 4x4 Blazer, with the Thermostat Housing, should there be a gasket or not?
Once the leak was found the tech that was looking at it found a gasket that was made to fit it and put it on and stopped leaks. So it's odd to me that there is a gasket made to fit it but the first tech says no, this truck is not supposed to have one. So all he had put was some paste/sealant to help make a seal without a gasket which I figured helped for a bit.
Thanks,
Old Jun 11, 2009 | 07:08 PM
carterx's Avatar
anyone have an idea for this?
Old Jun 11, 2009 | 08:21 PM
Geez man... 6 Hours... Please have patience.
The thermostat on your truck should have already came with a rubber gasket around the perimeter of the thermostat itself. This should be sufficient to seal the interface. If this gasket was misplaced or damaged, it would likely leak.
Installing a paper gasket between the two larger surfaces is a sure fire way to seal the leak, but just is not necessary when things are assembled properly. Sounds like mechanic #1 screwed up and mechanic #2 did not really know what he was talking about, but was still able to repair it for you.
jonwilliams
14
Nov 10, 2021 09:05 PM
RegSo
Sep 30, 2019 08:59 PM
bulwaagh
Oct 22, 2009 06:10 PM
skitzobmxr
Feb 9, 2007 07:49 PM
