Throttle suring
Old Mar 15, 2023 | 09:19 PM
PScholl68's Avatar
PScholl68 is on a distinguished road
Default Throttle suring
Throttle Suring at times when rolling at 45 - 55 mph it seems like the transaction and the engine aren't on the same revolution, I was wondering what to check first. It is a 2000 LT Blazer 4wd, have changed all vac hoses and still might think it's related to my 4wd actuator solinoid. Have read multiple posts on here could be a lot of things just want some thoughts on the subject, and where to start first.
Old Mar 15, 2023 | 11:23 PM
GeorgeLG's Avatar
Does the truck surge in speed or surge in RPM with no increase in vehicle speed?
George
Old Mar 16, 2023 | 02:07 AM
PScholl68's Avatar
Yes it will surge while driving with out pushing the throttle any more, it seems like it does it when it needs to shift gears but it will shoot the rpms over 2000 then it goes in gear and runs fine till you down shirt again then it will do it again. Some days it won't do it at all I've tried to watch for signs like the 4wd light on , then when it's out the 4 wd light on the dash will be on saying server 4 wd. And it will be sometimes off. If that's any help
Old Mar 16, 2023 | 03:04 AM
GeorgeLG's Avatar
Does surge mean the speed increases or the rpm increases but the speed stays the same?
George
Old Mar 16, 2023 | 07:36 PM
PScholl68's Avatar
Yes the tach jumps but no speed increase, it's like all of sudden it decides to jump the rpms but it seems like the engine dosent react, could it be a bad tach gage or maybe throttle cable needs adjusting. There are a number of ways in could go.
Old Mar 16, 2023 | 09:43 PM
GeorgeLG's Avatar
"it seems like the engine dosent react".
So the tach dial shows a higher rpm but the vehicle speed does not increase AND the engine does not actually increase in rpm? This is a tach gauge or rpm sensor problem only, the engine rpm is not actually surging/"reacting"? I just want to make sure that I understand what is happening here before we try to solve your problem
George
Old Mar 16, 2023 | 10:44 PM
PScholl68's Avatar
No the engine dosent react ,the rpm gauge surges then drops back down to normal ,
Old Mar 18, 2023 | 01:21 PM
GeorgeLG's Avatar
So this is a gauge problem because the engine and vehicle speed are unaffected? If so then there are a number of possibilities:
  1. The instrument cluster is defective
  2. The power or ground to the IPC are corrupt
  3. The VCM or its pwr/gnds is/are damaged
  4. The Crank sensor or its power/gnd is damaged (not likely if the truck runs good)
  5. There is a wiring fault from the crank sensor to the VCM or the VCM to the IPC
Getting to the bottom of this will likely not be easy. About the easiest trynostic move is swap IPC's to see if its the gauge even though I am not a fan of the parts cannon. I wouldnt swap the crank sensor since thats not likely it and then you will have to do a relearn. The next best move would be to check all the wiring, power and grounds (sensor, VCM, IPC). Then its monitor the tach input on the white A3 wire to the IPC to see if the tach signal goes up with the gauge but that would require a scope to do right. A digital meter on AC might be able to monitor that signal and show if the level moves with the gauge but we would have to do some experimenting.
Let me know what your up for and Ill help.
George
AceWolff
Jun 19, 2021 12:13 AM
DavidJohnson93312
Mar 18, 2019 09:41 AM
jbrooks19
Performance & Brainstorming
13
Dec 31, 2014 01:34 PM
bigkeith11
Dec 17, 2011 06:28 PM
Blazerboy1611
13
Feb 14, 2010 06:58 PM
