Torsion bar
Old Jan 19, 2022 | 04:30 PM
BritishColumbiafishing's Avatar
BritishColumbiafishing is on a distinguished road
Default Torsion bar
When would it be necessary upgrade or replace a torsion bars. I go out offroading very often. Running 32 in tires also
Old Jan 19, 2022 | 07:42 PM
AJBert's Avatar
I have almost 300k miles on my stock tbars on the Blazer and 260k miles on the 2500hd. I have never heard of tbars "wearing out", but the rear springs will commonly sag after a few years and mileage. If they ain't broke I say leave them alone.
Old Jan 20, 2022 | 10:29 AM
fair enough thanks. Yes the rear end has a 5 stack of new leafs now
Old Jan 20, 2022 | 05:48 PM
There info on the torsion bars on here and Google, there different "thicknesses". Maybe look into it and see if a set of zr2 torsion bars would work better.
Old Jan 21, 2022 | 09:21 AM
El_Beautor's Avatar
There were 5 or 6 different spring rate bars commonly offered on the S-series trucks. The higher spring rate bars were much less common on the non-ZR2s, so if you find that your front t-bars are not as stiff as you'd like, then a stiffer set from a ZR2 would be a good choice. In my experience the 30.69mm bars (2nd stiffest) were the most common in the ZR2 Blazers, while the pickups came with either those or the stiffest bars. I have the 2nd stiffest bars in my Crew Cab, and I think it rides much nicer and more truck like than the softer premium smooth ride t-bars that came OEM.
To find some donor t-bars, the bars have the last 3 digits of the part number stamped into the front end of the bar, or you could measure the diameter with a caliper. Here's a list of the possible t-bars:
Originally Posted by jsmz
now that ive said that here is the list of bars gm made
Part Number Bar Dia. NOM Torque
LH 15956501 26.63mm 1052
RH 15956502 26.63mm 1052
LH 15956503 27.94mm 1276
RH 15956504 27.94mm 1276
LH 15956505 29.36mm 1450
RH 15956506 29.36mm 1646
LH 15956509 30.69mm 1883
RH 15956510 30.69mm 1883
LH 15956511 32.51mm 2305
RH 15956512 32.51mm 2305
Brandon Koharchik
Jan 20, 2018 06:38 AM
blazernmike
Suspension Tech
Apr 10, 2013 12:45 PM
Jimmy_Blazer
Feb 22, 2012 10:50 AM
20Blazer004X4
Jul 26, 2009 08:27 PM
slickwilly
Oct 29, 2008 10:26 PM
