Suspension Tech Have a question about modifying your suspension? Ask it here.
torsion bar issues
Old Apr 6, 2013 | 07:25 PM
blazernmike's Avatar
blazernmike is on a distinguished road
Default torsion bar issues
i just bought this blazer and i went to go tighten the torsion bars to get a little bit of lift. When i looked at the torsion bars i noticed that the drivers side torsion bar adjustment screw is threaded out and the passenger side screw is tightened right up. Now the truck sits even height? any ideas on what could be wrong/broken?
Old Apr 6, 2013 | 07:49 PM
cleburne red's Avatar
Sounds like the passenger side was sagging and the previous owner adjusted that side to even it out. Torsion bars are like a coil spring stretched out straight. Over time they will weaken, and sag.
Old Apr 7, 2013 | 02:17 PM
ok so a way to fix this would be to, get new torsion bar? buy these keys I've been hearing about to get the more lift?
Old Apr 7, 2013 | 08:19 PM
I dont think keys would help in this situation. I would lean towards a new set of torsion bars together. I'm no expert, though. Definitely do some more researching around here before you put your money down.
Old Apr 7, 2013 | 10:13 PM
gitch93's Avatar
gitch93 is on a distinguished road
im having the same issue i lifted mine and the cranked the bolts all the way up from the added weight i added my tbars are sagging alot. gm canada discontinued the tbars and only sell them in the states. im trying to get my hands on a set of zr2 ones
Old Apr 10, 2013 | 10:23 AM
LeWhite's Avatar
Is there a good reason you need more lift? If its just for looks thats OK too. What you first need to know is your corner weights. The formula way is with scales in a wind tunnel. The Red Neck way is jack up the rear at the banjo and measure your left and right front height. Lift the front at the center, and measure the rear heights. Fix as needed to eliminate lean and wedge.
Old Apr 10, 2013 | 12:45 PM
gitch93's Avatar
the sag always happens over years of abuse. offroading and added weight to a vehicle that the oem bars were not esigned for makes them weaken. i have the premium ride package and the suspension was great for hwy use but not offroading so i upgraded the stock suspension to heavy duty parts. my bars have indexed keys in them and cranked all the way up the ride is sloppy and i bottom out easy in dips on the road. i managed to score a set of 2003 s10 zr2 torsion bars for 70 bux for the set. hope this will solve my issue
azzr2
Mar 25, 2012 04:19 PM
cloak01ls
Oct 14, 2009 01:11 AM
sledneck16
Suspension Tech
47
May 20, 2009 12:56 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
Bgray
Suspension Tech
Sep 10, 2006 04:45 PM
