towing problem
Old Dec 5, 2009 | 02:54 PM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
Default towing problem
ok so I put on a 2'' body lift with the lift bumper brackets and it says i cannot tow anything with the lift bumper brackets. it came with. Is this because the bumper brackets are not strong enough or the bolts it came with not strong enough? The bumper bracket also uses 2 less bolts to mount into the frame I was thinking if I were to reinforce the bracket with 2 more bolts would towing be able to happen or is it that the brackets are not strong enough?
Old Dec 5, 2009 | 10:22 PM
oisinirish's Avatar
Best bet IMO install a "Draw Tite" or equivalent type bolt on hitch with a receiever..then you can adjust tongue height as required by using a different drop on the receiver.
Old Dec 6, 2009 | 03:49 AM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
Brackets are not strong enough. Go with a Drawtite as already suggested.
Old Dec 6, 2009 | 06:56 AM
old skool luvr's Avatar
ummmm..........who does any amount of towing on a bumper?
personally, i wouldn't trust the rating for a bumper-regardless what the manufacture ays-have you ever seen a bumper flex 'n twist when it's towing something? it's not pretty or reassurinng.
Old Dec 6, 2009 | 01:11 PM
Default bumper towing
I've used the bumper for towing up until a couple months ago when i got the lift. I've pulled my 2500lb boat around for a year once a week pretty much and daily mowing business trailer and never had any problems of the bumper letting up or anything. But I will be buying a reese hitch or so sometime soon
hubert hefner
Jan 18, 2010 08:03 PM
Hellfish
Nov 11, 2009 09:28 PM
loodog
Jul 3, 2006 10:50 PM
tbrinker
May 30, 2006 04:48 PM
dmoore1200
Mar 15, 2005 09:52 PM
