98 2wheel drive lowered s10 blazer
i just purchased a 98 s10 blazer 2door 2 wheel drive it has been lowered with beltech lowering kit and it is framing out on the rear end what can i do, also has a bad vibration in front end over 65mph
C-Notch
Blazer with a notch
Click the links^
A C-Notch is where you cut a section of your frame out over the axle and replace it with a piece of metal in the form of a C, so you dont hit your axle on the frame.
Blazer with a notch
Click the links^
Suicidedoors.com sells bolt-in notches. Basically you notch the frame to allow more clearance for the axle so it does not hit the frame. You cut out a notch in the frame then add a c-notch to strengthen the frame.
The vibration may be caused by your pinion angle being out of alignment. Some rear blocks require an angled shim to keep the pinion angle correct. Take it to a dealer or shop and have them check your angle. If it's off then you will probably need to add the angled shims to your blocks.
Not at all. Notch is only like 2.25 inches.
http://www.suicidedoors.com/BlazerBolt-inC-Notch.php
This is my ride bagged. I still have my back seat and spare tire.
billyhoe
Nov 10, 2008 10:58 AM
