General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
98 2wheel drive lowered s10 blazer
Old Jun 10, 2006 | 07:12 PM
troy's Avatar
troy is an unknown quantity at this point
Default 98 2wheel drive lowered s10 blazer
i just purchased a 98 s10 blazer 2door 2 wheel drive it has been lowered with beltech lowering kit and it is framing out on the rear end what can i do, also has a bad vibration in front end over 65mph
Old Jun 11, 2006 | 05:08 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: 98 2wheel drive lowered s10 blazer
What size drop does it have?
You need to c notch your frame. And get an alinment done, they should tell you what is wrong with the front end.
Old Jun 11, 2006 | 09:10 PM
troy's Avatar
what do you mean c notch the frame im new to this. i bought it to eventually drop a 383 stroker in it
Old Jun 16, 2006 | 08:18 PM
blazin97's Avatar
C-Notch
Blazer with a notch
Click the links^
A C-Notch is where you cut a section of your frame out over the axle and replace it with a piece of metal in the form of a C, so you dont hit your axle on the frame.
Old Jun 16, 2006 | 09:56 PM
LORCLAS's Avatar
LORCLAS is an unknown quantity at this point
Suicidedoors.com sells bolt-in notches. Basically you notch the frame to allow more clearance for the axle so it does not hit the frame. You cut out a notch in the frame then add a c-notch to strengthen the frame.
The vibration may be caused by your pinion angle being out of alignment. Some rear blocks require an angled shim to keep the pinion angle correct. Take it to a dealer or shop and have them check your angle. If it's off then you will probably need to add the angled shims to your blocks.
Old Jun 20, 2006 | 09:16 PM
troy's Avatar
ok if i notch the frame as you just said will that mess up the interior, like the back seat and trim
Old Jun 20, 2006 | 09:41 PM
LORCLAS's Avatar
Not at all. Notch is only like 2.25 inches.
http://www.suicidedoors.com/BlazerBolt-inC-Notch.php
This is my ride bagged. I still have my back seat and spare tire.
bobby099
Lowering Tech
Jun 2, 2012 12:50 PM
hondaoneal22
Jun 27, 2011 09:39 PM
billyhoe
Nov 10, 2008 10:58 AM
syxpack
Oct 27, 2008 09:08 PM
CashSax
Suspension Tech
Jan 31, 2007 10:00 PM
