General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
99 blazer tranny issues... please help....
Old Apr 14, 2006 | 12:48 AM
wildcatxcr8's Avatar
wildcatxcr8 is an unknown quantity at this point
Default 99 blazer tranny issues... please help....
I have had a problem with the tranny in this thing. After long highway runs (15-35) miles when I come to a stop and take off again the trans. shifts real hard sort of like a shift kit. The check engine light has come on twice and I have two different readings or they may be the same. One scanner is code 1870 and with a different scanner, it says tranny slipping. Six months ago trans fluid and filter were changed (not flushed). New t-stat 195 deg. I dont know what the 1870 code is and was wondering if anyone has had the same type problem. There is talk about this problem looking back , but not much help Thank you ahead of time jw
Old Apr 14, 2006 | 10:53 PM
DINO55's Avatar
DINO55 is an unknown quantity at this point
Default RE: 99 blazer tranny issues... please help....
P1870 - Transmission Component Slipping
Old Apr 17, 2006 | 02:39 PM
Hanr3's Avatar
Make sure it is full of fluid, might not hurt to add one of those Tranny addatives.
Old Jun 23, 2006 | 09:36 PM
oosickness's Avatar
oosickness is an unknown quantity at this point
For 4L60E transmissions with Code 1870. This kit corrects wear in the valve body that causes code 1870. The reamer is specially designed for use with our TCC regulator valve kits 77754-03K and 77754-04K. This reamer allows the installation of our re-designed TCC regulator sleeve and valve and requires only cutting oil and a speed handle. The reamer also features a depth stop to prevent over boring. This fix will not work on GM remanufactured transmissions. The transmission doesn't need to be removed to install this part.
#77754-R2, Reamer. Cost $125.00
Qty 12345
#77754-03K, valve for 1993-1997 all except EC3. Cost $46.00
Qty 12345
#77754-04K, valve for 1998 up EC3 units. Cost $46.00
Qty 12345
http://www.transmissioncenter.net/4L60E.htm
Shaun Bogen
Dec 23, 2012 12:23 PM
armymedic
Apr 12, 2011 06:07 PM
snaumo
Aug 31, 2009 01:03 PM
rogggg1020
Nov 11, 2008 08:05 AM
Zack98Blazin
Aug 30, 2006 05:45 PM
