General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
adding oil to floor jack
Old Sep 9, 2006 | 05:57 PM
gmaltese's Avatar
gmaltese is an unknown quantity at this point
Default adding oil to floor jack
hello .. i know this is not a blazer problem, but to work on my blazer i need the jack, it's a sears 3 ton jack, it only goes up half way, id like to know how to add oil to it , here is a pic of it please help thanks glen ( i hope the pic shows up)
[IMG]local://upfiles/3527/16802553567147008E4E1E996D812348.jpg[/IMG]
Old Sep 9, 2006 | 06:25 PM
hillbillyinOhio's Avatar
Default RE: adding oil to floor jack
First thing I would do is power wash it and try to get some of the crap out of it. Then I would spray it with some LPS or WD40 to get the water back out and then try to lube it up some.
Old Sep 9, 2006 | 10:28 PM
Is there a cap/plug on the cylinder (in front of the handle)?
Old Sep 9, 2006 | 11:00 PM
gmaltese's Avatar
nothing on the cylinder, just a flat head and an allen head that you can see from the pic, i dont want to unscrew any thing because it might be under pressure
Old Sep 9, 2006 | 11:06 PM
If the jack handle is twisted all the way to release, nothing should be under pressure. One cap will probably have a spring and check ball under it, the other should be the fill port.
Old Sep 9, 2006 | 11:24 PM
gmaltese's Avatar
i'm going to look at the front of the handle again i was on this site and saw this http://www.hyjacks.com/H7.HTM thanks for you help.... glen
Old Sep 9, 2006 | 11:40 PM
gmaltese's Avatar
after looking at the jack again i lowered the handle all the way down and low and behold there was a rubber stopper,just like the one in the link i posted, pulled it off and saw some oil down there, so thats it! thanks for helpping out, now i can rotate my tires on my 98 blazer 4.3l 213,000 miles and counting
Old Sep 9, 2006 | 11:52 PM
I could have sworn that most all jacks have a fill hole in the main body of the cylinder.
Old Sep 11, 2006 | 12:07 AM
gmaltese's Avatar
jack works great now, thanks for you help
cleburne red
May 25, 2013 07:52 PM
mr.vls
Mar 21, 2012 06:10 PM
Rottidog
Jan 11, 2012 04:47 PM
CubanDan
Engine & Internal
Aug 14, 2009 10:34 AM
pinetopfirefighter
Mar 2, 2009 08:25 PM
