Dreaded door hinge question.
Hi. I need to replace my passenger side door hinge pins. I had done the driver's side a couple years ago. My question is, since GM decided it was a good idea to weld the hinges to the door and body, what do we do when the hole in the hinge gets too worn? Is it a job for the body shop at this point? In my case it looks like I can get by with replacing the bushings, but looking at it made me curious. Doesn't look like a good design to me.
just did it a few weeks ago, was pretty easy, then went to a body shop and had them put those damn springs back in for me instead of me buying the took to use it twice in my life.
ORIGINAL: frankjc
It's done...finally, except for the spring. The last time I did this there were 3 of us working on it, 2 holding the door, and 1 putting the pins in. We got the spring in with prybars. I tried it this time, but I got too frustrated. I used a chair that was just about the right height to hold the door, with a jack under it. Took about 20 minutes. Now I have to get the spring in there.
I have this problem with my driver's door... I was told by the Chevy body shop that they can replace the pins but in a couple of months it'll just be the same problem again since the holes are worn out and that YES I should be looking to replace the actual hinge. It is a welding thing and would need to be done at a body shop... so I didnt bother doing the pins and I'm going to wait till I can afford it done right.
billfrank85
May 11, 2012 06:33 PM
