General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
engine light flashing
Old Sep 22, 2006 | 11:34 PM
tammikm's Avatar
tammikm is an unknown quantity at this point
Default engine light flashing
on the highway tonight while passing a car the engine light began to flash maybe 6 - 10 times then went out, what does that mean? it is a 2001 trailblazer, and has never done this before.
thanks
Old Sep 23, 2006 | 02:03 AM
20Blazer00's Avatar
Default RE: engine light flashing
Have the computer scanned for DTC's. One indication is that there are cylinder misfires. And need to be taken care of. When was the last time the truck was tuned up, wires-plugs-cap-rotor etc.
Old Sep 23, 2006 | 09:27 AM
tammikm's Avatar
tuned up a year ago but just got plugs, should I have it looked at? its not flashing anymore.
Old Sep 24, 2006 | 04:18 AM
20Blazer00's Avatar
I would find someone with an OBDII scanner to see if the computer has stored codes, these don't set off the engine lights but are stored in memory, if the problem that caused the flashing engine light is not corrected or gets worse then it will turn the light on. If it fixes itself or was just a temporary situation the code will be removed from the computer after a predetermined set of "drive cycles". Some times this can be as little as three starts and stops or I have read that some codes will take 40+ "drive cycles" to self remove after setting the light... so if the light stays off in the same situation then the problem will have been temporary and the computer will not set a more permanent code...
AutoZone has been known by many to check codes for free...that is one avenue to get them checked without paying the dealer a fine for hooking up the scanner....
dtp12
Jun 4, 2011 06:52 PM
65Cents
Aug 19, 2010 08:52 PM
zombiewoof
Feb 1, 2009 12:06 PM
tammikm
Dec 14, 2006 06:28 PM
