General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
fuel filter on 94 s10 blazer
Old Aug 7, 2006 | 06:35 PM
94blazerowner's Avatar
94blazerowner is an unknown quantity at this point
Default fuel filter on 94 s10 blazer
Ok where is the fuel filter located on the 94 s10 blazers? Under the hood or by the fuel tank. The reason im askin is mine is runnin shoddy and i was thinkin maybe it was the fuel filter.
Old Aug 7, 2006 | 07:35 PM
Dan's Avatar
Dan
Dan is an unknown quantity at this point
Default RE: fuel filter on 94 s10 blazer
it is behind the framerail on the driverside right in the middle of the truck. Generally right under where the back door is, that is if it is a 4 door.
Old Aug 15, 2006 | 10:58 AM
cimbali's Avatar
cimbali is an unknown quantity at this point
Default (fuel pressure)RE: fuel filter on 94 s10 blazer
What's is the best way to releave fuel pressure on this truck? thx
Old Aug 18, 2006 | 12:09 AM
Dabber's Avatar
Dabber is an unknown quantity at this point
Default RE: (fuel pressure)RE: fuel filter on 94 s10 blazer
If I am correct there is a valve under the hood on the fuel rail. Looks like tire valve, twist off cap(if there is one on it) and push on the valve inside it. Make sure to have a rag handy for the fuel that will come out.
Old Aug 18, 2006 | 09:20 AM
A much easier way to relieve fuel pressure is to pull the fuel pump relay and try to start the truck. It'll relieve it without spraying fuel out...
aerovette99
46
Sep 28, 2015 10:04 AM
95jblaze
Aug 27, 2011 03:46 PM
brianroark
Jun 25, 2010 03:14 PM
Chalz
Dec 4, 2008 06:11 PM
riverjamie
Sep 24, 2007 08:21 PM
