General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Gurgling noise?
Old Jun 21, 2006 | 03:39 AM
black19's Avatar
black19 is an unknown quantity at this point
Default Gurgling noise?
OK, I have heard it talked about briefly before, but what is that weird gurgling noise from the passenger side of the car? I have only heard it maybe a handful of times from my car but I figured I should look into it. Any ideas?
Old Jun 21, 2006 | 05:50 AM
Chevy Lover's Avatar
Default RE: Gurgling noise?
ORIGINAL: black19
If you are hearing this gurgling noise while the engine is running, I would suggest checking the coolant level. Ckeck the overflow tank is at the full level - cold, and check the level in the radiator.If it's low, check for leaks.
Old Jun 25, 2006 | 06:03 PM
frankjc's Avatar
frankjc is an unknown quantity at this point
That happened to me. My coolant level was low, due to a leaking water pump.
Old Jun 25, 2006 | 08:25 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
The gurgling can also be caused by blockages in the heater core, I have back-flushed mine and still have it.
Old Jun 26, 2006 | 07:15 AM
ORIGINAL: cherryred4x4
Sorry I had to laugh but it's late and I was just thinking....6 speakers, 2 subs, 1700 watts, hmmm, how do you hear gurgling?
Seriously thou, are you sure you bled out all the air from the cooling system?
Old Jun 26, 2006 | 10:02 PM
yeah, I changed the radiator recently because it had developed a small leak where the end cap met the core, and got all the air out of the system, new 16lb stant cap too. I ran it with the heater core fully open until the thermostat opened up, then shut it off and let it cool down. Repeated that process several times, also on ramps. I changed from Dexcool to the green stuff a while back, and thought I got all the old coolant out with a flush, but I think the heater core is partially blocked by hardened Dexcool. The problem developed shortly after the change, about 1 year ago.
I dont play the stereo all the time, usually real quiet at lights, I hear the gurgling the most often when pulling away from lights.
Old Jun 27, 2006 | 06:42 AM
DINO55's Avatar
DINO55 is an unknown quantity at this point
You just gotta love those wonderful after affects of Deathcool...
gmon3y15
Apr 2, 2014 12:18 AM
jlucey2
Oct 29, 2010 10:45 AM
WeimerHeimer
Jan 29, 2010 08:35 PM
ComputerNerdBD
Aug 7, 2009 12:54 AM
Balam
Mar 8, 2007 06:19 PM
