VERY weird gurgling sounds
Old Mar 7, 2007 | 10:36 PM
Balam's Avatar
Balam is an unknown quantity at this point
Default VERY weird gurgling sounds
Hi guys I have a funny one for you today... every time I rev the engine in neutral I get a gurgling sound from within the dashboard. It happens wheather I have the heater valve open or completely shut off... what could this be????
Balam
Old Mar 7, 2007 | 10:50 PM
Mapoftazifosho's Avatar
Mapoftazifosho is an unknown quantity at this point
Default RE: VERY weird gurgling sounds
The heater core.
Old Mar 7, 2007 | 11:45 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Well it is air in the heater core. Do a search and you will find a ton of info on on this subject.
Old Mar 8, 2007 | 03:18 AM
Chevy Lover's Avatar
Yup, check your rad level when cold and you'll find that it's low.
I'm glad that you see it as "funny"....check carefully for coolant leaks.
Old Mar 8, 2007 | 06:19 PM
JustBlaze!'s Avatar
JustBlaze! is an unknown quantity at this point
Like Chevy Lover said, check carefully for coolant leaks. The little leaks are hard to find especially if you use dexcool since it oxidizes and Temporarily seals the leak. I heard a similar gargling noise a month before my intake manifold gasket went. I learned the hard way when the buildup of oxidized dexcool finally went and my truck pissed out all of its coolant.
gmon3y15
Apr 2, 2014 12:18 AM
jlucey2
Oct 29, 2010 10:45 AM
WeimerHeimer
Jan 29, 2010 08:35 PM
ComputerNerdBD
Aug 7, 2009 12:54 AM
black19
Jun 27, 2006 06:42 AM
