'97 Chevy Blazer - Gurgling under Dashboard
Old Jan 28, 2010 | 03:42 PM
WeimerHeimer's Avatar
WeimerHeimer is on a distinguished road
Default '97 Chevy Blazer - Gurgling under Dashboard
In the last few days my Blazer has started to GURGLE when;
1) I first start it.
2) I make a quick turn at an intersection.
I do get a brief period where I can smell Coolant fluid when I first start it up, but then it goes away.
I checked the Coolant level and it was NOT low. Heat is fine. Defrost is fine (no fogging of windshield when in defrost mode). No coolant leaks inside or outside the vehicle. Temp gauge shows no over or under heating, it's right on.
Any ideas what might be going on?
Lon H.
York, PA
Old Jan 28, 2010 | 03:45 PM
tazz9690's Avatar
tazz9690 is on a distinguished road
You might have air in the system.
Old Jan 28, 2010 | 06:21 PM
rriddle3's Avatar
Yep, I would both flush the heater core and purge the air from the system.
Old Jan 28, 2010 | 10:56 PM
not_only's Avatar
not_only is on a distinguished road
And if there is no coolant leak, you should check/ change the radiator cap also.
Old Jan 29, 2010 | 09:14 AM
ZR2nut's Avatar
ZR2nut is an unknown quantity at this point
X2 on all the above
Old Jan 29, 2010 | 02:16 PM
Could you please tell me how to flush the heater core and purge the air from the system? I'm not a mechanic by any means. I can handle changing the cap, but don't know anything about the other two processes.
Thanks!
Old Jan 29, 2010 | 03:34 PM
rriddle3's Avatar
Disconnect both hoses to the heater core on the outside of the firewall. Connect a garden hose to the inlet and run water through until it comes out clear. Repeat the procedure for the outlet to the core.
To purge air raise the front of the vehicle with the passenger side slightly higher remove the radiator cap and run the engine to operating temperature watching for air bubbles at the filler neck. Add coolant as needed let the engine cool and repeat procedure. Possibly a third cycle.
Old Jan 29, 2010 | 05:21 PM
Sirloin's Avatar
Sirloin is on a distinguished road
Wink Flushing the heater core
good instructions rriddle.
I disconnect the heater hoses from the engine ( it was just a little easier to reach and work ).
Old Jan 29, 2010 | 08:35 PM
chillblaze's Avatar
chillblaze is on a distinguished road
Default air in system
Yep , I agree mine is doing same thing just haven't had time to do it yet, changed fluid a few weeks ago and the air went to heater core
gmon3y15
Apr 2, 2014 12:18 AM
jlucey2
Oct 29, 2010 10:45 AM
ComputerNerdBD
Aug 7, 2009 12:54 AM
Balam
Mar 8, 2007 06:19 PM
black19
Jun 27, 2006 06:42 AM
