Heater core gurgling?
Old Oct 23, 2010 | 12:34 PM
jlucey2's Avatar
jlucey2 is on a distinguished road
Default Heater core gurgling?
Hello was wondering if anyone is having issues with there heater core in the dashboard of 2001 chevy blazer?have a swushing sound on accelerating checked for leaks none did a backflush of heater core all good pressure test held don't smell any anti freeze reserve tank full and radiator full does anyone have any ideas?
Old Oct 23, 2010 | 12:36 PM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
mine does too. i've learned just to deal with it. you've already flushed it out so other then replacing it or running a system cleaner through it there is not much else you can do.
Old Oct 23, 2010 | 12:39 PM
jlucey2's Avatar
Ok was wondering what do you think causes it? Thanks for your input
Old Oct 23, 2010 | 12:46 PM
contaminants in the coolant and/or in the heater core
Old Oct 24, 2010 | 06:13 PM
AJBert's Avatar
You have air in the system, plain and simple. Get the air out and the gurgling will be gone.
Old Oct 24, 2010 | 06:44 PM
cbr995's Avatar
I used to have that issue. I checked the radiator, and it was actually low from when the previous owner replaced it. I made sure the system was filled up, and it went away. At least that's how I fixed them.
Old Oct 24, 2010 | 06:57 PM
warthogdriver's Avatar
check your hoses...mine had a very small split allowing air in when the pressure would change...to rid air out of system fix hose (if applies) remove rad cap on COLD start. run the engine add antifreeze/h2o while revving the idle till it looks "fuller". easy fix.
Old Oct 25, 2010 | 08:59 PM
abig84's Avatar
alot of time its the evap drain clogged from the a/c ive unpluged those things and have seen up to a gallon of water come out of there
Old Oct 29, 2010 | 03:03 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
My 97 did that too so I replaced the heater core flushed the whole system refilled it ran it and got all the air out and did evrything your supposed to do to get rid of airlocks and after I was done and the system worked perfect it still gurgled under the dash. I learned to live with it until I sold it.
Old Oct 29, 2010 | 10:45 AM
getmoney1576's Avatar
getmoney1576 is on a distinguished road
i was just dealing with this problem myself abt a month ago so thought id add my 2 cents...i had gurgling of water in my dash thought nothing of it week later my trucks over heating. i replaced water pump and thermostat truck stopped over heating but still had gurgling asked a buddy of mine he says its the heater core and to replace it so that weekend we did just that and replaced it.. so far no gurgling of water...
gmon3y15
Apr 2, 2014 12:18 AM
WeimerHeimer
Jan 29, 2010 08:35 PM
ComputerNerdBD
Aug 7, 2009 12:54 AM
Balam
Mar 8, 2007 06:19 PM
black19
Jun 27, 2006 06:42 AM
