General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Just a post to say THANK YOU. [No spark = dead coil]
Old Oct 28, 2006 | 02:06 PM
MIKER's Avatar
MIKER is an unknown quantity at this point
Default Just a post to say THANK YOU. [No spark = dead coil]
Our 2000 Blazer died intermittantly, 3 or 4 times, then finally died and wouldn't start.
I searched for the answer here on the Blazer Forum and found it.
It turned out to be the coil.
Being that it has ~120,000 miles on the odometer, I went ahead and changed the distributor cap, rotor, wires and spark plugs along with the coil. Hopefully I can squeeze another ~80,000+ miles out of it without too much trouble.
This post is where I found the answer:
No Spark
https://blazerforum.com/m_27292/tm.htm
Discussion forums such as this one have saved me loads of cash.
I just wanted to say THANK YOU to everone for sharing their experiences to the benefit of others. [sm=icon_cheers.gif]
Mike
Old Oct 28, 2006 | 03:34 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Default RE: Just a post to say THANK YOU. [No spark = dead coil]
That's what we are here for! I'm so glad you found info on this site to help you out!!!
Old Oct 28, 2006 | 08:29 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
YEP that's why we're here...welcome to the site.......glad you fixed your problem...and don't hesitate to ask if you need help with your blazer again. By the way just normal maintenance and you'll EASILY hit that 200K mark!!!
Old Oct 29, 2006 | 12:17 AM
MIKER's Avatar
I made a victory post just a bit too soon. [sm=sigh.gif]
The Blazer started cutting out and died again. This time my wife was ~70 miles from home when it happened.
I arrived with our car hauler in tow, luckily the Blazer started up and died twice but made it up onto the trailer under it's own power.
Having the same problem as before really through me for a loop. I had no doubt that the old coil was the culprit due to the fact that it was literally burned on one side and that the Blazer started right up and ran great immediately after replacing it.
However, I have isolated and repaired the actual problem. The weather pack connector which plugs into the top of the coil contains two wires. A red wire which supplies voltage and a white one which supplies signal.
The white wire was broken within the insulation about 1/4" above the weather pack connector. It was intermittently loosing contact, thus causing the engine to die.
The bottom line is that it is running well once again.
I can only speculate that the burned spot on the side of the original coil may have occurred due to the poor connection in the broken wire!?!
Mike
Old Oct 29, 2006 | 01:19 AM
Chevy Lover's Avatar
Good work MIKER, I hope I'm not congradulating you to soon!
keithjannjr1994
Mar 11, 2014 01:17 PM
rviolette84
Dec 18, 2012 07:01 PM
azzr2
Mar 16, 2012 01:08 PM
BDS_237
Apr 19, 2010 11:05 PM
ken erestu
Dec 13, 2006 07:35 PM
