General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Leaking Transmisson Fluild
Old Aug 5, 2006 | 01:58 AM
SoDakBlazer's Avatar
SoDakBlazer is an unknown quantity at this point
Default Leaking Transmisson Fluild
I got a 2000 Blazer 4 Door 4x4 auto transmisson. I am leaking a lot of transmisson fluid near where the trasnmisson dipstick tube goes into the tansmisson, I cant tell wheter it is the whole tranmisson gasket, or the little rubber seal where the dipstick tube meets the transmisson. Has this happened to anybody, or do you know if this is a common problem. Any Suggestions of what I should do?
Old Aug 5, 2006 | 06:21 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: Leaking Transmisson Fluild
Welcome to the site! first you need to find out EXACTLY what is leaking. It is probably on of the transmission line fittings. Both of the lines attatch to the trans in that general area (just above and behind the dipstick tube). It could be the dipstick tube seal or the pan gasket. But , like I said, you need to identify EXACTLY where it is coming from before I can give you any real advice.
rjck1979
Dec 29, 2009 04:15 PM
rsither
Aug 13, 2009 10:29 AM
muleman
Nov 25, 2008 12:43 PM
99 Blazer 4 door
Performance & Brainstorming
Aug 29, 2008 10:46 AM
BlaZeR FXB1581
Engine & Internal
Jan 27, 2006 07:45 PM
