General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
More A/C Issues
Old Jul 10, 2006 | 03:54 PM
PAGuy77's Avatar
PAGuy77 is an unknown quantity at this point
Default More A/C Issues
I just recently had my 1995 Blazers A/C system recharged, and a high pressure valve replaced because it was leaking freon. The A/C system was doing just fine for a while, then all of the sudden it would start to work intermittently. It would run for about 5 - 10 minutes then not run at all. Now it isn't running at all. A friend of mine said it might have something to do with a pressure switch. However, there are quite a few pressure switches/valves w/ an A/C system, so it is hard to tell which one it could be. I was wondering if anyone has had this problem. If it is a switch, what switch could it possibly be, how easy is it to replace, and can it be replaced w/o evacuating the system again. Any help on this issue would be greatly appreciated. Thank you very much.
Shawn
Old Jul 10, 2006 | 04:17 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Default RE: More A/C Issues
The AC cycling switch is the most common thing but that would keep it from workinfg at all... not intermitten so I dont think that is the problem
i think its low on freeon there is a leak somewhere the condensors are common to leak... usually by the lower pass side corner i would suggest getting a shot of tracer dye and looking for am leak with a uv light.
that comes straight from a friend who works for chevy as a shop manager. hope it helps...
Old Jul 10, 2006 | 04:30 PM
PAGuy77's Avatar
Thanks Dory. However, when the A/C was last recharged, a dye was put through the system. I will have to check to see if there are any leaks. The freon levels are where they should be according to the gauge I have. Thanks again for getting a professional's take on the issue.
Shawn
Old Jul 10, 2006 | 04:32 PM
Dory's Avatar
as well as that, if the truck is overheating or the fan clutch is bad, the ac will not work as well
Old Jul 10, 2006 | 04:46 PM
PAGuy77's Avatar
ORIGINAL: Dory
Thanks again Dory. No problems with overheating and the fan works just fine. Thank you for helping me try and rule out things before I take it to be serviced.
Shawn
Old Jul 10, 2006 | 05:16 PM
Dory's Avatar
Well I would still look for a leak... but if a presure switch needs to be replaced, it should be able to be done without evac and recharge. I know that on the newer ones, the ac cycling switck does not require that and usually its the switch right next to the reciever/dryer (the thing that looks like a metal can under the hood)
Old Jul 10, 2006 | 07:37 PM
PAGuy77's Avatar
ORIGINAL: Dory
Thanks again. Is there a way that I can check to see if it is the cycling switch before I take it in to the shop? What would I have to do?
Shawn
Chenzo
Engine & Internal
Mar 29, 2011 01:56 AM
dwhittaker
Mar 14, 2011 02:18 PM
dougs10
Dec 14, 2010 03:24 PM
Twiztedshot
Jun 27, 2010 07:19 PM
LIL4X4S10
May 24, 2010 04:33 PM
