More 4x4 issues
Old May 24, 2010 | 03:27 PM
LIL4X4S10's Avatar
LIL4X4S10 is on a distinguished road
Default More 4x4 issues
Well here i am again i have a 1994 s10 blazer tahoe lt. it has the push button 4x4 but when i use it it will lock it and with light gas pedal usage it will stay locked, but when i give it a lil more gas the back wheels only turn? i know i need a front driver side axle b/c i hace grease all over the axle where it busted. im wondering if that may have something to do with it?
Old May 24, 2010 | 03:49 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
The c/v boot problem shouldn't have anything to do with your front axle engaging. You need to see if your front axle is fully engaging. It kinda sounds like it may not be and that could be anything from a bad shift motor to a leaky vacuum actuator or the engagement cable. How's your vacuum lines and switch on the t-case?
Old May 24, 2010 | 03:52 PM
LIL4X4S10's Avatar
well when i climbed under it there are no vac lines unless there on top of the t-case im not sure. but i know when i engage all four wheels are locked in. but when i add more power to it it slips out and only the rear wheels will spin???
not to mention this is my first push button 4x4
Old May 24, 2010 | 04:33 PM
The lines are on top of the transfer case just behind the forward u-joint on the t-case. That's where the switch is with 3 lines to it. One is vacuum in, another is vacuum out (goes to your actuator) and the third is a vent. When the motor engages, it puts power to your front driveshaft but the front differential is still not enagged until the vacuum is ported to the actuator to pull the cable to engage the front end. This switch is what does the "porting". Really works the same as the older 231 t-case except the motor shifts the t-case from 2H to 4H & 4L instead of a lever. The lines run over the top and can be a bit of a bugger to find. If your hand isn't solid black with all the road grime, etc. you haven't got close enough yet. Trust me, they're there. I would next suspect the actuator having a hole in it. It;s under the battery tray. Check the lines first.
Got the same truck as you do.
Chenzo
Engine & Internal
Mar 29, 2011 01:56 AM
dwhittaker
Mar 14, 2011 02:18 PM
dougs10
Dec 14, 2010 03:24 PM
Twiztedshot
Jun 27, 2010 07:19 PM
PAGuy77
Jul 10, 2006 07:37 PM
