General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
rear brake rotors
Old Nov 7, 2006 | 10:57 PM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
Default rear brake rotors
does anyone know how to get the rear break rotors off a 99 blazer... i got the front two done and cant for the life on me figure out how to get the rear off
thanks
tim
Old Nov 7, 2006 | 11:14 PM
Default RE: rear brake rotors
Most likely the internal drum parking brake is hanging up. You are going to need to try and pull out while turning the rotor. Hopefully it will get past the rusted lip on the internal drum hat...
*EDIT* - Here's my post on the subject: Rear Disk Brakes...
Old Nov 8, 2006 | 12:20 AM
so if i just yank the rotor of it wont like mess up the e brake will it?
Old Nov 8, 2006 | 01:43 AM
Chevy Lover's Avatar
It might help to adjust the park brake cable for more slack first. Also, push the park brake lever closer to the backing plate if you can, (sometimes the cable sticks a bit). Kyles' probably right that the rotors are hanging up on the shoes internally.
If you pull the rotors off and the shoe comes out with it, the only damage will probably be to the clip that holds the shoe to the backing plate. That little spring clip is replaceable.
blazer blaze13
Apr 7, 2010 05:31 PM
busch393
Dec 18, 2009 08:31 PM
red_dragon
Aug 2, 2008 07:03 PM
EuroGoldLS
Sep 6, 2007 06:47 PM
blazerxtreme1
Suspension Tech
Jul 3, 2006 01:57 PM
