Brake rotors? 4wd & 2wd
Old Sep 6, 2007 | 01:25 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default Brake rotors? 4wd & 2wd
Whats the difference between the 4wd and the 2wd brake rotors? I've been shopping around for some brake rotors because mine are warped and cannot be resurfaced any further an I came across some in JCWhitney, but they have them for 4wd, but not 2wd. Whats the difference? or Is there a difference?
Old Sep 6, 2007 | 01:34 PM
99 Blazer 4x4's Avatar
99 Blazer 4x4 is an unknown quantity at this point
Default RE: Brake rotors? 4wd & 2wd
I justreplaced mineabout 6 months ago and when I went to the parts store the looked themup and said that they were the same part number. I went to O'reilly by the way. If your rotors are warped be sure to check the calipersbecauseon mytruck it was about 1 month after I noticed the brake shimmy andcheck that I was able to afford the frontand rear rotors and pads because I wanted tochange everything atonce. It caused the passenger caliper to go bad. Sothen of course I also replaced 2 calipers also.
Old Sep 6, 2007 | 02:18 PM
EuroGoldLS's Avatar
No Its not the calipers causing it. It was me being stupid. I washed it right after I had drove it and sprayed the disc.
Old Sep 6, 2007 | 03:16 PM
The difference between 2wd and 4wd came into play before they switch the 2wd front bearings over to a similar sealed unit as the 4wds have. Before this change was made, the front disks on a 2wd were also the entire hub assembly, housing the bearings as well. Your truck should use the same front rotors as the 4wd, but rear rotors (assuming 4wheel disk) are different for some reason...
Old Sep 6, 2007 | 04:14 PM
EuroGoldLS's Avatar
Its all disk (thank goodness). I have ceramic pads on the back that are pretty much brand new and I have some slightly worn semi-metal ones on the front that will be replaced with the rotors. I'm gonna go all the way around with some cross drilled rotors.
Old Sep 6, 2007 | 06:15 PM
Be careful with crossdrilled rotors. There is actually no benefit to cross drilled rotors due to the decrease in actual pad contact area coupled with the decrease in structural strength if they are in fact drilled standard rotors. To be as strong as stock, the holes must be cast in. You'd be better off with slotted rotors.
Old Sep 6, 2007 | 06:47 PM
EuroGoldLS's Avatar
These won't be stock drilled rotors. They'll be Brembo or Wilewood. I will probably go with slotted. or Slotted & drilled.
red_dragon
Aug 2, 2008 07:03 PM
lionel2
Feb 4, 2008 04:45 AM
MVPalmer271
Dec 30, 2007 12:41 AM
timetoblaze
Nov 8, 2006 01:43 AM
blazerxtreme1
Suspension Tech
Jul 3, 2006 01:57 PM
