General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
sensor
Old Jul 27, 2006 | 06:21 PM
Biggjay's Avatar
Biggjay is an unknown quantity at this point
Default sensor
has anybody had problems with the throttle position sensor?? I'm having fits
with mine... '99 Blazer 4.3
Old Jul 27, 2006 | 11:49 PM
Hanr3's Avatar
Default RE: sensor
I had to replace mine this spring on the '00.
Old Jul 28, 2006 | 02:18 AM
Chevy Lover's Avatar
Default RE: sensor
What kind of problems are you having? You can check the tp sensor with a digital voltmeter.
Here's a pretty basic check. I usually use a pin to pierce the wires and clip the voltmeter to the pins.
Observe the TP sensor while depressing the accelerator pedal with the ignition turned ON leaving the engine OFF. The display should vary from about 0.5 volts (500 mV) when the throttle was closed to over 4.5 volts (4500 mV) when the throttle is held at WOT position
joey
Aug 27, 2012 06:33 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
