General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Sponsored by:
Sponsored by:
sensor
Old 07-27-2006, 06:21 PM
Biggjay's Avatar
Biggjay is an unknown quantity at this point
Default sensor
has anybody had problems with the throttle position sensor?? I'm having fits
with mine... '99 Blazer 4.3
Old 07-27-2006, 11:49 PM
Hanr3's Avatar
Default RE: sensor
I had to replace mine this spring on the '00.
Old 07-28-2006, 02:18 AM
Chevy Lover's Avatar
Default RE: sensor
What kind of problems are you having? You can check the tp sensor with a digital voltmeter.
Here's a pretty basic check. I usually use a pin to pierce the wires and clip the voltmeter to the pins.
Observe the TP sensor while depressing the accelerator pedal with the ignition turned ON leaving the engine OFF. The display should vary from about 0.5 volts (500 mV) when the throttle was closed to over 4.5 volts (4500 mV) when the throttle is held at WOT position
joey
08-27-2012 06:33 PM
GM hater
01-09-2010 02:32 PM
theeviltwinn
10-23-2009 06:37 AM
daniel010
02-02-2009 06:50 AM
Spartan66
07-11-2008 02:34 PM
Quick Reply: sensor
