simple question
make sure that the new ***** inner diameter is slightly larger then the levers outer. otherwise u may have to fabricate an extension to the lever. no big deal, i used a tappered piece of wood, which the tapered end going into the lever. i then fit a copper ring i cut from an old pipe around the other end to be able to tighten the set screw on the new ****
thebigjimmy
Dec 22, 2009 10:38 AM
BIGGER_HAMMER
Nov 21, 2008 02:00 PM
