General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
The squeak from hell!
Old Oct 23, 2006 | 06:04 PM
bat119's Avatar
bat119 is an unknown quantity at this point
Default The squeak from hell!
The back tailgate on my 4 door 99 S10 Blazer squeaks when driving, tried WD-40 and spray silicone it only worked for a short while. Is there a adjustment to make the door close better?
Old Oct 23, 2006 | 06:46 PM
DCFluX's Avatar
DCFluX is an unknown quantity at this point
Default RE: The squeak from hell!
Cut a piece of silicone hose, with about 5/16" Inner Diameter. I used a Help! kit molded vacumm hose. I don't have the number but it was $2.99 and shaped like a "L".
Cut about 1" from an end and jam that on the metal peg that is sticking out from the glass, next to the latch. Once the hose is on there take a razor and trim it so that about 3/16" - 1/2" of the metal peg is visable past the end of the hose. Close the glass gently the first time and it should work fine there after.
Old Oct 24, 2006 | 03:13 AM
stinger74's Avatar
stinger74 is an unknown quantity at this point
I've heard of guys buying new latches or adjusting the existing ones. So far those are the only things I've heard of that've worked.
Old Oct 24, 2006 | 09:17 PM
Brian J. Lesko's Avatar
Brian J. Lesko is an unknown quantity at this point
I have the same problem. I usually just spray down the weatherstipping with some silicon or some penetrating oil. It usually will last a few months before it starts up again. I just do it everytime that I change the oil.
Old Oct 25, 2006 | 04:20 AM
Annekat91's Avatar
Annekat91 is an unknown quantity at this point
Sounds like there are better solutions, but I spray WD-40 into the latch mechanism, and I recently found out that it lasts a lot longer if you wiggle the moving part of the latch in between squirts. The other thing I want to try, aside from replacing the weatherstripping, is using thick RTV silicone to build up the worn areas in the two upper corners of the weatherstripping.
Anne
'91 S-10 Blazer
2dr, 4X4, 4.3L
153,000 mi.
94s10blazin
Sep 24, 2018 10:38 AM
WickedBlazer
Sep 12, 2012 03:14 AM
thrash902
Sep 15, 2010 10:52 PM
deoverton
Mar 1, 2009 04:40 PM
swoopes_30
Feb 20, 2006 02:33 PM
