General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Starting trouble
Old Oct 9, 2006 | 02:39 AM
95blaz4x4's Avatar
95blaz4x4 is an unknown quantity at this point
Default Starting trouble
I have a 95 2dr 4x4 Blazer. Its has about 162,000 miles on it. I have to turn the key a couple times to get it started. Usually i turn the key once starter spins no action. Second turn and the truck starts normal. Sometimes it takes a couple more turns of the key to start. Has this happened to anybody else? Does anybody has any suggestions what to look for to be the problem?
Old Oct 9, 2006 | 02:49 AM
Chevy Lover's Avatar
Default RE: Starting trouble
Is the battery fully charged?
When was your last tune-up...plugs, cap, rotor, air and fuel filter?
Have you run any fuel injector cleaner through the system?
Have you checked the fuel pressure?
Old Oct 9, 2006 | 10:01 AM
95blaz4x4's Avatar
I have put a new battery in within the last year. I did spark plugs just recently. Cap and rotor 24k ago. I haven't tried the fuel injector cleaner which ill try today. Fuel filter i changed that about once a year. I'm going to give the injector cleaner a shot. It seems seafoam is a popular suggestion on here and change the filter after that. The fuel pressure i havent found out what it was supposed to be at to see if mine was right. If i remember correctly i have 48 psi of pressure when i checked it last. I heard it was supposed to be more than that. Thank you for the suggestions so far.
Old Oct 9, 2006 | 10:10 AM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Could it just be that your starter is starting to show signs of damage? Maybe its starting to go bad?
Old Oct 9, 2006 | 10:32 AM
95blaz4x4's Avatar
i thought of that too. I just didnt want to but one if it didnt need it. Im going to try that after the seafoam. Plus they never look fun to do. Thanks for the suggestion.
ynoth
Jan 8, 2010 01:28 AM
jaredwaugh
Nov 8, 2007 03:49 PM
fivemillerz
Jul 17, 2006 08:26 PM
dcjones
Jan 19, 2006 10:54 PM
danimalvt
Engine & Internal
Dec 20, 2005 08:32 PM
