General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Sticky accelerator pedal
Old Oct 8, 2006 | 12:15 AM
frankjc's Avatar
frankjc is an unknown quantity at this point
Default Sticky accelerator pedal
Once in a while, my gas pedal seems to stick. It happens when I let off the gas, then step on it again, it seems harder to press. Thankfully, it doesn't get stuck in the "open" position, for lack of a better word. Is there anything common that causes this?
Thanks.
Old Oct 8, 2006 | 01:59 AM
magnum434's Avatar
magnum434 is an unknown quantity at this point
Default RE: Sticky accelerator pedal
yea go remove the air duct thing on top of the throttle body and open the butterfly valve and spray some carb/throttle body cleaner around on the walls and scrub with a tooth brush or someting...itll run like crap for a really short time but yea...thats all...
looks like i need to do this as well...
Old Oct 8, 2006 | 02:34 AM
I'll start off by asking the obvious... Did you make sure that your floor mat isn't getting in the way?
Ok now that that is out of the way, you could remove the throttle cable from your TB and move it back and forth. Then work the TB itself.
If you narrow it down to the cable, then look for kinks in the cable itself between the TB end and where it goes through the firewall. If that looks fine, go in under the dash (you'll have to remove a hush panel). See if anything is restricting the motion of the pedal from inside the cab.
If you narrow it down to the TB, then I would recommend removing the TB and giving it a thorough cleaning.
Old Oct 8, 2006 | 04:08 AM
billthegoat's Avatar
billthegoat is an unknown quantity at this point
....I was going to suggest checking the floormat too. I can laugh because it's happened to me.
Old Oct 8, 2006 | 04:55 AM
magnum434's Avatar
yea...go with what he said...haha im a nerd who wishes he knew what he was talking about...but it is a good idea anyways to clean ur throttle body...so post up with wat u find.
Old Oct 8, 2006 | 09:15 AM
hdlogistics's Avatar
hdlogistics is an unknown quantity at this point
I had the same problem with my Grand Marquis. I cleaned the throttle body and sprayed the heck out of the tv cable to loosen it up. Stopped sticking after all was cleaned. Use a good crab cleaner and it should fix it all..
[quote]ORIGINAL: magnum434
Old Oct 8, 2006 | 10:13 AM
ORIGINAL: magnum434
Magnum, I was in no way saying your suggestion wasn't right.. In fact cleaning the TB should be a rainy day preventative maintenance item for all of us to help keep everthing working like it should.
It never fails that the obivous is overlooked.
Old Oct 8, 2006 | 01:08 PM
magnum434's Avatar
No I mean I like what you said narrowing the options down...and your smarter...im going with you. I didnt take it that wrong. Looks like I have someting to do when i get off work though...hehe
Miketalley87
Apr 1, 2021 12:05 PM
redrider76
Mar 25, 2013 05:55 PM
stevie59
Jan 7, 2011 11:07 PM
c0a8l0v6i8n9
Mar 14, 2010 02:45 PM
RedOctober
Oct 10, 2006 02:06 AM
