Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Need Quick Help Please!
Old Feb 22, 2010 | 06:13 PM
PaulO2288's Avatar
PaulO2288 is on a distinguished road
Default Need Quick Help Please!
I have a Flowmaster exhaust on my 99 4dr Blazer and i was wondering if I can swap it over to my new 2000 Blazer 4rd. But from the cat back they have different bolt ups. The 99 has 3 bolts to make a triangle and the 2000 has 2. Also the 99 has a Y pipe in great condition where as the 2000 one is shot. So I was wondering if both Y pipes are the same so I can swap over the Y pipe back from the 99 to the 2000 and make it fit since then it will have the same bolt ups but i need to make sure both Y pipes are the same. Anyone know please? Thanks
Old Feb 22, 2010 | 06:43 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
overall i believe the piping for the exhaust should be the same which would be 2.5", i'd get a second opinon on the y pipe. they should be releativly close but idk if they had a small difference in the jump between 99 and 00
Old Feb 22, 2010 | 08:10 PM
oktain's Avatar
hmmmm... Look at the mounting connection point between the down pipe and the y-pipe... if that's the same between years, then the swap should be doable. The frames aren't different, so one y-pipe will fit under either truck... Get it? It all depends on if the bolts match up or you may be swapping Down pipes as well...
Old Feb 22, 2010 | 10:24 PM
PaulO2288's Avatar
Well since the exhaust bolts are different from the cat back i want to swap the y pipe and from there back, so pretty much from the headers back shall i say. So the Y pipe that goes to the cat, then to my flowmaster to the tailpipe
Edit: Just checked, They all look the same just different from the cat back with the bolt pattern. It should go no problem. The
Y pipe on my red truck is so destroyed and disgusting
Old Feb 22, 2010 | 10:53 PM
old skool luvr's Avatar
you mean exhaust manifolds, right?
i can't see anyone going o the work of putting in headers, then installing a (custom) Y-pipe on them.
the systems will boult up no problem by the way.
Old Feb 22, 2010 | 11:07 PM
PaulO2288's Avatar
Yeah meant the mainfolds back. So the manifolds are staying on, unbolting the y pipe and back and installing to the minfolds on my new truck. Thank you by the way
Old Feb 22, 2010 | 11:09 PM
on behalf of everyone that replied to your question, i can safely say "no problem".
Old Feb 22, 2010 | 11:34 PM
ABN31B's Avatar
<-- for my contribution...
BLAZERMAN911
Feb 22, 2011 01:52 PM
11Bravo
Jul 3, 2010 12:36 PM
vetteman61
Jan 12, 2007 04:32 AM
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
V6 Vortec Jimmy
Sep 21, 2005 07:56 PM
