Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
V-force muffler
Old Sep 3, 2006 | 03:04 PM
blazinloud's Avatar
Default V-force muffler
got a v force muffler put on yesterday, its identical to the flowmaster 40.
problem is on take of at low rpm i get this ratteling sound now but i goes away at close to 2k rpm. it dosent really sound like metal to metal ratteling........it kinda sounds like a little dirt bike and then it goes away when i reach the rpm. could this be the fault of a hole in the weld or something to do with the install, or is it just how its supposed to sound?
fyi i saw side by side pics of the v force and the 40 series and they do look identical
Old Sep 10, 2006 | 01:39 PM
blazinloud's Avatar
Default RE: V-force muffler
bump
come on guys, help a brother out [8D]
Old Sep 10, 2006 | 02:37 PM
jagblazer01's Avatar
ORIGINAL: blazinloud
they may look identical but its how the inner chambers are worked is the important thing. As far as your rattle...who put it on? was it you or a shop? if it was a shop take it back and have them look it over
Old Sep 10, 2006 | 03:03 PM
I would demand that they put another muffler on and see if it goes away. You paid for that right.
Is the tip a weld on or clamp/bolt on? If it's a clamp/bolt on, try taking it off and see how it sounds.
Old Sep 10, 2006 | 05:03 PM
blazinloud's Avatar
Ok tire and muffler put it on. The seems are welded, but the welds look quite sloppy.
The first day they put it on it sounded absolutly horrible at take off, but then the 'ratteling' would go away once i was over say....13-1400 rpm. Its been about a week and the ratteling has gone away some-what, well enough not to drive me insane
also what else can i do to the exhaust at a reasonable price?
Old Sep 19, 2006 | 02:54 PM
blazinloud's Avatar
bump! Well my mechanic says my cat is shot, i take it they're capable of ratteling?
Would it be worth it to put an aftermarket, high flow on, or should i just stick with stock.
If I go aftermarket, are there any online site that sell them?(other than e-bay)
thnx
-Adam
Old Sep 19, 2006 | 07:09 PM
tommyd's Avatar
tommyd is an unknown quantity at this point
As far as a cat goes yes that could cause the rattleing. The catalyst can break apart and get stuck in the muffler and rattle. I say ditch the stock one since you need a new one go with an aftermarket hi flow I know summitracing.com sells them.
kamilkowalski
Apr 30, 2015 08:36 PM
Parkonahill
Performance & Brainstorming
Oct 20, 2008 08:14 PM
dimmuborgir6nik6
Jan 12, 2008 02:35 AM
mdehoogh
Aug 10, 2007 08:50 AM
2000ZR2
Dec 3, 2005 09:17 AM
