Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
would it be okay
Old Feb 18, 2009 | 08:49 AM
spankyy's Avatar
spankyy is an unknown quantity at this point
Default would it be okay
would it be okay to just take an put a k&n cold air intake air filter an just put the filter right on to the maf sensor
i no it sounds dumb
Old Feb 18, 2009 | 09:01 AM
rriddle3's Avatar
Default RE: would it be okay
I think it would put too much restriction on the air flow at the MAF sensor. The sensor needs a free flow of air to do it's job.
Old Feb 18, 2009 | 09:02 AM
BudRacing's Avatar
BudRacing is an unknown quantity at this point
Has it been done? Yes
Is it the best setup? No
Is there a chance the oiled filter will get oil on the sensitive MAF wires? Yes
IMO, a hacked airbox and a drop in replacement filter will get you the same results as a "Cold air intake". These engines really don't have too much trouble breathing once you open it up a little.
Old Feb 18, 2009 | 09:05 AM
spankyy's Avatar
okyay thats what i wanted to no lol how big of holes do u put in the stock air box
dose any one mabey have a pic of it
Old Feb 18, 2009 | 10:55 AM
BudRacing's Avatar
Everyone does the box mod differently. I had some hole saw drill attachments that were 1.5" and I drilled 3 holes. One in the bottom, and two on the side facing away from the engine. It really freed things up. Some cut the whole front off, which is probably what I should have done.
Old Feb 18, 2009 | 04:01 PM
spankyy's Avatar
well i just took an made the front hole alot bigger an put a 2in hole it the bottom an two 2 in holes in the side that face the motor will that be okay i misse read what was sayed an i put them in the wrong side will it be okay
Old Feb 18, 2009 | 05:18 PM
Modifying the box by drilling holes may actually decrease your performance. If you just want to open things up a bit, just remove the tube (helmholz resonator) from the front of the air box and call it a day. Reason being, all those holes just allow air from under the hood (hot air) to be drawn into the engine which sort of defeats the purpose. That is the largest problem with these "cold" air intakes out there. They do nothing to actually seal off the filter from hot engine bay air.
Old Feb 19, 2009 | 08:46 AM
spankyy's Avatar
well it seamed to help out fer now till i can get a cai
calee4nyaboy
Nov 20, 2009 11:48 PM
davtak
The Chop Shop
Sep 4, 2008 12:48 PM
gstrat323
Tires and Wheels
Apr 22, 2008 08:35 PM
2001BlazrLS
Detailing
14
Mar 28, 2008 08:29 PM
Coldspot
Jan 14, 2008 06:05 AM
