2-3 In. suspension lifts that don't require a t-bar crank
Old Aug 1, 2007 | 01:25 PM
aris_unlimited's Avatar
aris_unlimited is an unknown quantity at this point
Default 2-3 In. suspension lifts that don't require a t-bar crank
The title pretty much says it all does anybody know of a 2-3in suspension lift kit that does not require the t-bar to be cranked up?
Old Aug 1, 2007 | 08:09 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: 2-3 In. suspension lifts that don't require a t-bar crank
you left part of the title off.... the sentence should say; "Two to three inch suspension lifts that don't require a torsion bar crank do not exist." I believe what you have there is called a sentence fragment..lol
Old Aug 1, 2007 | 09:37 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Yeah there is nothing that height other than a body lift, which does not do anything to the suspension. You could do a 2" body lift, and 1.5-2" shackles in the rear and a 1-1.5" t-bar crank, shouldnt put too much extra stress on the cv shafts and ball joints, but you would definately need check them often, at least at every oil change and make sure they are lubed up real good. This would allow you to run 31" tires which will give you about an extra inch of frame-ground clearance.
-Lenny
Old Aug 2, 2007 | 12:07 PM
ok so let me ask a new question how high of a suspension lift do I need to get before I don't have to worry about a t-bar crank.........I know sometimes with the higher up ones they just replace a bunch of stock parts to make their lifts work
Old Aug 2, 2007 | 02:26 PM
Yeah you would need either the Trailmaster 5" or 6" or the Superlift 6" kit. These run between 1400 and 2000 dollars plus shipping. I can't recall if Rough Country makes a lift kit for the blazer other than the 2" new a-arms and tbar crank one. Just do some searching on the web, 4wheelparts.com is a good site to check out, otherwise google s-10 blazer suspension lift.
JimmyRiggin
22
May 12, 2010 12:16 AM
papacope
Jan 18, 2010 11:49 PM
RedNeckWagon360
Apr 3, 2009 11:53 AM
scattym
Lifting Tech
21
Feb 22, 2009 10:01 AM
cherryred4x4
Suspension Tech
19
Sep 8, 2006 08:08 PM
